Tim, watched your latest video above, some good points there but I'd like to comment on the Hemi vs Hurricane.
The same engineer may have designed those 2 engines, but that doesn't guarantee that the design parameters/requirements are at all the same, nor that he can just make decisions that are independent of what his bosses want him to do. The hemi is a 20 year old engine, Chrysler built that motor just as much as Alan did. Now we have Stellantis in charge 20 years later, the inevitable engineering tradeoffs that are made could completely different. For a start, fuel efficiency and pollution is more important than longevity. We see them making that decision with the oil choices with the hemi over time already.
Secondly, the hemi is still a far simpler motor. Pushrod, cast iron block etc. Let's not underestimate this, that hemi has a completely solid lower end. GM builds essentially the same motor in aluminium and cast iron blocks, the aluminium does light duty stuff like camaro and 1500, the cast iron goes in their heavy duty trucks. These are conscious choices by the designers, cast iron is stronger, it handles heat far better etc.
Then we get into turbos. Not "if" they go, but "when" they go. We get into issues like heat while towing.
Next issue that makes me wary is the use of direct injection. I'm sorry but there is no excuse for the way they did this, Ford figured this out years ago already; multi-injection is what works, you get direct injection for the fuel efficiency and power gains, but port injection to keep everything clean and tidy. Carbon buildup will be a serious issue in these engines over time as Ford discovered. GM has the same problem, just DI.
And finally we have Ford, the original guy in the market, building very powerful turbo engines in the F150 but spending millions to build a N/A 7.3/6.8 for use in their heavy duty trucks. Just another sign that it's not about the peak power numbers, turbos can definitely pull the weight needed for a heavy duty truck, but it simply cannot survive the duty cycle of a typical F250/F350. Ford knows this, that's why there is no turbos in their super duty.
Note that the 5.7 hemi is the only gas engine used in a half ton, that also was used in a heavy duty truck (2500). It was the base engine for years in the 2500. Only difference was some very slight cam tuning and no MDS vs the 1500 5.7. That's some rock solid pedigree. You will not kill the 5.7 by working it hard, as long as it is well maintained.
I'm not going to say the hurricane can't do well in a 1500 use case. But I am going to suggest that the 5.7 will be proven to be more more reliable/indestructible over time vs the hurricane. (Hemi tick issue is not a durability thing, it's just a manufacturing defect from one of their vendors. It's not caused by working the engine too hard, for example.).
I will not be inline (heh) to buy one of these engines anytime soon. Hopefully my truck will be with me for a long time. If I total it and need to replace it, I'll buy a used hemi before a hurricane. And in the future when ram charger is available, that looks like the better choice by far then these hurricane options.
All my 2 cents.
All my 2 cents.
