I’ve been talking and asking about direct injection with regards to carbon buildup for years. I actually asked Alan about that and got a WTF kind of look back. Engineers are of the opinion this is a fixed issue IMO. It just never comes up anymore in my discussions.Tim,
Yeah remember that video and his discussion and linked back to it on you tube where top commenters had the same concern as I do and which wasn't addressed:
"I think the biggest problem is still not addressed, that is carbon buildup in the intake valves. It’s my understanding that carbon/ dried sludge builds up on the intake valves from the PCV introducing oil vapor into the intake valves building up crud, because in the normal course of port injection the deposits would be washed away from building up on the valves otherwise. Direct injection eliminates this of course. That is why they have added this 2 way punch of port and direct injection. It’s still not clear how GM is addressing this issue beyond using both as Ford and others have done."
"It's the crank case blow by that gets returned to the intake through the pcv that creates intake valve coking. Valve coking is worse on turbo charged engines, which is the point for ecoboost having port and direct injection. The port injection helps to clean the back of the intake valves."
From 37:10 to 37:20 Alan talks about how the bad gases are ventilated from the crankcase and go back through the combustion process. But as the earlier comments to the GM video detail, the PCV system sends the gas with the dirty oil back through the intake manifold...Where detergent gasoline doesn't spray anymore because of the 2000psi fuel atomization occurring in the cylinder. But here is the end result for the consumer:
Timestamp Chapter 4, 3:47 for the valves.
Believe this is something GM and RAM will accept and and tell customers to walnut shell (or trade it in!) while Ford has partially addressed it, but not as clean as full-time port injection.
Moot point in the end, just have to keep my L36, LMG, LC9, and SI6 motors.
I feel like this issue isn’t going away with the videos I’ve done though. That tells me I haven’t either asked the right question or gotten the right answer. Terrence, whose comment you quoted, has been on and off with me on this for at least 4 years.
I wonder who to interview now that people would actually believe. LOL. I tried Stellantis, I tried GM, so… either Ford or Toyota.
