New Clutch Plate Update
C-Square
Member
Finally, I get to share an update on the forum. The clutch plate was replaced this past August 2024 under the recall issued in the spring of 2023. In one quick summary: What a difference. The gears engage smoothly and precisely, the gear lever gives the perfect feedback which means that the driver never has to look down to know where the lever should go.
I chose the Gladiator precisely because I wanted to stay with a truck, but I was missing the manual transmission. Of course, when the recall was issued, I questioned my move, but now I feel comforted in my decision. I am sure the Tacoma would have worked too, but I thought rear drum brakes for a heavy vehicle could present potential situations. At the time, the current Tacoma was not yet available. If I were to pick a trim now, I would pick the TRD Sport manual.
I enjoy driving the Gladiator Rubicon both on and off road.
I'm curious on your thoughts on this: "I thought rear drum brakes for a heavy vehicle could present potential situations."
I had a VW Jetta SE manual (2011) with rear drum brakes and, prior to that, a Saturn SL manual (2001) with rear drum brakes. The Jetta had ABS, the Saturn did not. This set-up was never an issue with these vehicles because they are light ones. I drove 20 years with both combined, and I never thought of the drum brakes while driving. When I decided to buy a truck, the weight of the vehicle became front and center, especially when in motion (physics). I felt like being careful in my selection because I was a novice in the truck world. Also, I live in New Jersey and we have all kinds of weather. The Jeep Gladiator Rubicon is even heavier than the Chevrolet Silverado 1500 RST 6.2 that I used t own (albeit by some 40 lbs.). To give an example of what I mean by being extra careful because I feel like a novice in the truck world, I realized that braking with the knobby tires of the Rubicon trim required an adjustment AFTER purchasing the vehicle. I did not test drive a Tacoma back in 2023 when I was shopping, and now my concern is moot since the new Tacoma has disc brakes all around. I would still choose the Gladiator for the rear passengers comfort (which is why I think the Gladiator would be a good vehicle for your wife when the kids travel with her).
As someone new to trucks, i'm a bit nervous about size. How's the gladiator been for everyday driving and parking? Any tips for a potential first-time truck owner?
It's all relative. To me the Gladiator is easy. Then again, I learned to drive when everything was a boat. If you learned to drive in a Corolla, then a Gladiator could be very daunting.
Overall, any of the mid-size trucks should be fine. Just takes some getting used to and practice if it's new and bigger.
The manual Gladiator is easy at stalling... It is a heavy truck mated to a low torque engine with a light weight flywheel . try reversing up a slight slope , and then imagine taking your off road Jeep on some extreme off road situations .
If you are used to driving a minivan, the main issue will be the same: the length. You probably noticed, a scratched minivan is usually hit on the side, in the second half of the vehicle. That's because the driver cut too much while turning. All I keep reminding myself is to wait an extra moment before turning. Otherwise, the width is just fine and feels normal. Let me know if that helps.
