Pics were from Tacomaworld.com which are from the leaked forbes articles. This is from 4Runner6G.com:
"Like prior 4Runners, the new model also shares a lot with the latest Tacoma midsize pickup including the powertrains. Toyota’s increasingly ubiquitous 2.4-liter turbocharged four-cylinder will be under the hood of all sixth-generation 4Runners. The standard i-Force version delivers 278-hp and lb-ft of torque. The hybrid i-Force Max adds an electric motor and 1.87-kWh nickel-metal hydride battery for a total of 326-hp and 465 lb-ft of torque. Towing capability grows from 5,000-lbs to 6,000-lbs.
The wheelbase of the new model has grown by 2.4-inches and overall length has grown by 4.7-inches compared to the old model. The longer overhangs mean the approach and departure angles are slightly degraded for the new 4Runner at 32 and 24 degrees respectively compared to 33 and 26 degrees for the four-wheel-drive fifth-gen. However, the nearly 20-inch shorter wheelbase compared to the Tacoma should give the 4Runner a big advantage over the pickup in breakover angle.
Both options come with the same eight-speed automatic transmission found in the Tacoma and Land Cruiser. As before, customers can choose a rear-wheel-drive, part-time four-wheel-drive or full-time four-wheel-drive system. Both 4WD systems have a two-speed transfer case and Toyota’s active traction control system to aid in sending torque to the wheels with the most grip. All variants get an automatic limited slip differential.
In addition to all of the usual trims found on Toyota trucks and SUVs, the 4Runner also offers the new Trailhunter trim. The Trailhunter includes ARB's Old Man Emu (OME) 2.5-inch forged shocks with remote reservoirs on the rear axle and a custom ARB roof rack. 33-inch Toyo Open Country all-terrain tires provide the grip along with two-inches of added front ground clearance and 1.5-inches in the rear.
Rock rails and high strength steel skid plates come standard on the Trailhunter along with a bronze grille and integrated 20-inch LED light bar. Toyota has also built in a 2400W inverter to power gear during overlanding adventures.
The 2025 4Runner goes on sale in fall 2024."
Almost 5 inches longer than the previous 4runner... I speculated they would shrink it a bit to separate from the new LC. Swing and a miss. Now the pricing alone will tell the story... 20" shorter wheelbase if correct will be huge for the Off-Road/Overlanding community. If true, that makes the 4Runner the king of off-road for Toyota (something a lot of people already claim.)
