Blue Oval 5.0
Active member
The 2.3 I-4 is direct injection only, or was until 2024 Mustang models I believe. I don't know if Ranger gets dual injection or not. Maybe Tim can shed some light on this.With that data, I'd take the 2.3L all day long. That's a proven motor that does everything well. I don't see much advantage in the 2.7L other than bragging rights. And if you want those, the Raptor is the obvious choice. Plus, for the 2.7L, those power numbers are with premium fuel only. Also, it's DI only where the 2.3L is DI/PI, correct?
The second generation of the 2.7 V6 (2018+) has both direct and port injection. Ford's site says Ranger with 2.7 V6 runs on regular unleaded but only has power numbers for running on premium for the 2.7 and 3.0 (in Raptor). The 3.0 is direct injection only as far as I am aware of.
From the Owner's manual (I bolded the last paragraph):
Your vehicle operates on regular unleaded gasoline with a minimum pump (R+M)/2 octane rating of 87.
Some fuel stations, particularly those in high altitude areas, offer fuels posted as regular unleaded gasoline with an octane rating below 87. The use of these fuels could result in engine damage that will not be covered by the vehicle Warranty.
For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer. See Towing a Trailer.
So the 2.3L runs on 87 but for best engine performance, they recommend 91. Take that FWIW. Contradicting information at best.
